Front suspension noise
I have been having this odd noise for a while when I hit bumps. It happens more at slower speeds. Just sounds like something loose. First I was thinking ball joints, replaced those and it is still there. I have HR springs in good shape, sway bar links look ok. I jack the car up and cant wiggle the wheel so I assume tie rod ends are ok. Whats next?
oh, forgot, struts are new kyb's, bought them from a member on here along with the springs. rides great
Quoting PushinInkTattoo:
check your sway bar end links again any little bit of play can make it sound like your front end is falling apart
