Front Lower Bushings Question
2of9
IGH, MN
Hey all, I was thinking about getting these bushings. It says it's for a 1g. Do we use the same front (lower) bushings as the 1g AWD? The car tends to vibrate after a quick small bump on the road. The front rims has some play to it when I wiggle it..and i can clearly see that i need new bushings. Thanks!
Hertz
Chicago, IL
They should be the same. I am not certain.
Are you sure this isn't a problem with wheel bearings? Tie-rod ends? Ball joints?
boostedinaz
Scottsdale, AZ
Iteresting. They say it is for a 1G yet they show the 2G suspension.
Yes the bushing should be the same for a 1G and a GVR4. On my Talon the original motor leak oil and it killed that bushing making it very squishy. My alignment was all over the place and once I replaced it the car felt a 100% better.
I would go over the suspension to make sure you are actually fixing the problem and not just throwing parts at it.
2of9
IGH, MN
thanks guys. I'll post up some pics of the bushing im talking about. ugh...just found out my passenger rear caliper might be sticking!!! ARHG!
