Front engine mount support
GEDengineering
Miami, Fl
Well I removed the front engine mount support ( the one that runs parallel with the engine)and both the bolts broke when I removed them (snapped in two pieces) their is still a piece of the bolt on both sides in the unibody rails
My question is has this happened to people before and if so what have you done to replace the bolts
Thank you
GED
tektic
ronkonkoma, ny
You can look up the part number on caps or at the dealership and order a factory bolt, but any grade 8 or above bolt in the same size should from your local hardware store should be fine.
Now getting the broken ones out of your car... there in lies the problem.
GEDengineering
Miami, Fl
Do you know whether it is a stud that screws into the frame rail of the uni body or is it welded in
Do you have an exploxed diagram of that section of the car
Thank you
GED
