FIC o ring seal question
Terry Posten
Davenport, Iowa USA
Yes. Remember that the aftermarket injector must fit inside the rail and head. So yes, they will fit.
The only thing that is a toss-up is the spacer that holds everything nice and tight. I had to trim them a little shorter on a set of RCs if I remember correctly.
HHIVR4
Hilton Head Island SC
Go ahead and get the viton seals from fic.Same price as stock ones and you can usually reuse if you upgrade injectors later.Opinions may vary but Ive had good luck with them and used the same set on 3 different sets of injectors.
vapid
IL
Quoting speedyvr4:
Will OEM injector seals fit FIC injectors?
I don't think they will fit, iirc the OEM isolators or whatever (top seals) were larger in id when compared to the FIC. Thats just my experience.
Plus, from what FICs site says, they will not fit. link
HHIVR4
All but 1 of the stock ones will fit FIC's..I think its the bottom or top one not %100 sure tho.
I dont remember when I changed mine. Just get the ones from FIC or take them down to a auto parts store and natch them up..
vapid
IL
^^^so it slips right in? Mmmmmm, lube.
speedyvr4
miami, fl
i went ahead and bought the ones from FIC. Satan tried to rob me for like 66 bucks for all the seals, shop price too.
