Few ?'s about VR-4.. Tranny+Check engine light...
Ok, I bought #390 of 1000... I absolutly love it!! No rust, good paint, doesnt burn oil, leather is perfect, $1500.00... The only problem is that 2nd and 3rd grind... Could I adjust the clutch or change the tranny fluid?? Would that help any?? If it keeps doin it will it eventually just blow the tranny?? Also a few times sitting at a red light idleing the check engine light would come on... Id touch the gas pedal ever so lightly (so lightly that it wouldnt even rev the engine) and it would go off (the check engine light)..
ghostinthevr4
Fresno, Califonia
Sounds like you got a sweet deal on your car, that grinding sounds like your synchros are going out I don't think the fluid will fix it. As for the check engine light try getting a Haynes manual and go at it from there with diagnostic codes good luck bro.
jared50438
garner,ia
my gsx does the same thing! i beleive its is the tps actually! last time i checked codes i had tps, coolant temp and air intake temp fixed the sensors and thought i brought tps to the right %/ voltage but thats all i can think of on it.
