Exhaust question
There's a large leak in the downpipe/frontpipe on 1899, enough so that it requires replacement. I've heard and read that both 1G/2G pipes should work. The entire exhaust system needs an upgrade which I will get to eventually, but as I am jobless at the moment (and a college student), such a thing is simply not in the cards. Doing a search of local automotive "junk" yards has turned up no such parts, however. Does anyone know where I could get a stock 1G/2G downpipe which would correctly match up to the stock system? eBay even turns up nothing except 3" systems.
belize1334
Bozeman, MT
The reason that 2G pipes are popular is that they are longer so you can do away with the cat/test pipe. Running one of those will require you to modify your oem exhaust system (if that's what you have). I have a stock GVR-4 downpipe that you could have for super cheap if you just want to slap it on as a replacement. Otherwise I'd get a 1G pipe since it won't require elimination of your cat etc.
All right, good to know about the 2G. Yeah, I just need a replacement pipe for a few months until I can afford a complete turbo-back exhaust upgrade. What would be the price for that stock GVR-4 downpipe you have? And if I went with a 1G replacement, hypothetically, would that require any modification, or would that be a simple matchup?
belize1334
Bozeman, MT
I found my certified muffler 2.5" dp to be exactly the same length and shape as my oem downpipe but you may run into issues with the bolt holes on the flange being too big. You definitely won't be able to get a 3" dp (the most common size) to bolt up. If you want my oem dp I'll give it to you for $20 + shipping. It's not very heavy but it is a little long so shipping might be another $20.
2of9
IGH, MN
the 1g is a direct bolt on. I have the 3" dowpipe from a 1g and there are no modifications you'd need. even the 1g test pipe will work.
Quoting Silvertooth:
Sorry to hear about your issue money is tight for everyone. But I will have a full turbo back exhasut for sale in a week(Cheap). Or I could just sell you the downpipe. PM..
