Hi GVR4.org
I finally got around to installing the Evo8 seats I picked up.
The fronts needed some fab to get installed of course, so that was not too bad.
The Rears are a different story.
I got the upper part of the back seat to fit ok but, the lower half is a not as easy.
There is some kind of brace or I guess you can call it a mount, attached to the floor.
The OEM Galant seats have space cut into the foam to allow the mount to go into the bottom seat.
The Evo8 rear seat is thiner, and cannot have the foam shaped for the mount.
If the mount was removed the lower rear Evo8 seat would fit.
My Question is, Can I remove (cut out) the mount?
Will removing the mount cause a problem with the rigidity / structural integrity?
pics...
and for anyone wondering about the 18in Volk GTCs
drivers side front rubs when sus bottoms out. I think its the fender liner.
Front seat slider modification.
pics...
