GVR-4
I'm in the middle of installing my EVO MR Bilstein struts and I wanted to share how I wish I had done one thing differently. For the rears everybody has been welding the bottom mounts between the ears (fork) of the EVO struts. Before I took them to a friends to have the mounts TIG welded in place, I tried a purely mechanical method, that I wish I had stuck with. I put the mount in position in between the fork blades and used some 1g head bolts to squeeze the fork blades together. I had to notch the mount with a cylindrical shaped bit and a die grinder so the bolt would pass from one fork blade through to the other side. I used two washers from the head bolts on each end of the bolt because there is not enough thread on the bolt shaft. Two washers between the fork blade and the head of the bolt and two washers between the other fork blade and the nut. The nuts from the stock Galant strut-to-hub mounting bolts fit the head bolts perfectly. I tightened the nut until it wouldn't turn anymore due to the threads on the bolt ending. There were five points of contact; two at the top, one front, one back (as installed on the car) and one at the bottom where the notch (in the mount) and the bolt make contact. I wish I had taken photos as I'm sure this is hard to vizualize. The more I have thought about it, the more I think this method would have been sufficiently secure, moreso than welding in some ways. Unfortunately, hindsight is 20/20 and my mounts are now welded in place. I could have avoided heating up the strut (risking damage to it and melting the rubber in the mount) and taking the time to hack up the fork and have my buddy do the welding. Maybe someone else can avoid my mistake. I can snap some photos of some of the stuff like the bolts if it will help anyone better understand what I'm trying to say.
Maybe this could be added to the plethora of EVO suspension install threads in the How To section.
