Evo 8 Shifter Console and Boot Molded to Galant Console
QnzMostWanted
Orlando, FL
mind you this is a long process, it takes more prep work than anything else
if u can get another shifter console to work with its up to you, I only needed the original
start with the shifter trim off of an Evo 8 or 9, Not the MR, the setup is different
I started with just a small mockup of the shifter, I trimed the curved edge where the shifter console curved to the boot to fit and cut the shifter trim from the evo bigger than the console and sat it underneath using the OEM square trim piece to hold it in place
once I determined exactly where the shifter is going to lie I trimmed it to a more defined fitment and from the bottom i sanded and scraped the edge and using fiberglass and bondo I formed the joint on the bottom (if u do not sand and scrape the underneath the bondo and fiberglass will have nothing to hold onto, thus making ur shifter useless (sorry no pics)
top after the bondo was hardened
I then filled the top with bondo, forming a uniformed top, sanded, til it was smooth, tested for strength by pressing on the edges to see if it held. sanded until it was perfectly smooth and i could not see the joint lines between the 2 plastics, then used sandable filler primer and sanded yet again
painted the trim with Trim paint...u can use any color, just use a nice satin color
it would look glossy til it dries
finished product using EVO 8 shifter boot and trim ring
sorry I dont have pics of the underside, but its pretty much just molding the pieces together
GL and when your done, grab an EVO 8 Steering wheel and it would help it flow much better
