ETACS? Where is the unit
Hey I am trying to diagnose another (shocking) problem with my galant.
List of things not working correctly:
Seatbelts don't move
tach doesn't move
temp gauge doesn't move
intermittant wipers don't intermittant
I get a beep when I open the door.
Cruise starts to work but almost immediately stops.
I am attributing all of this to a dead ETACS unit (you know that wonderfull mitsu masterpiece that sets off your alarm but lets you still drive the car...)
Where is the ETACS unit? Up over the clutch pedal there are 2 boxes one black plastic the other steel both with a ~18wire plug going into them. Is either of them it?
Before the Tcase died on me, I was having intermittant problems with the tach and gauges not working, but if I kicked around the fuse box they usually came back to life, but not anymore.
Thanks,
Dan
Maybe you need to stop kicking and find the loose or broken wiring causing your intermittent.
The ETACS is the box attached to the junction block. The junction block is where the interior multipurpose fuses are.
Hertz
Chicago, IL
ETACS does not control the instrument cluster. Your tach and temp gauges are being affected by something else.
tach doesn't move
As someone else said, the tach gets driven directly by the transistor, no ETACS involved. It gets its power from the instrument cluster.
This is either related to the tach issue, because of a voltage problem in your instrument cluster, or could be a bad/disconnected sender under the hood. No ETACS here either.
Do a search. Several people have had this problem, and it is one of those relays above the fuse box, if I recall.
Again, do a search. If the red light on the stalk goes out when you try to activate the cruise, I did a big post on this one time, and someone recently reposted the pictures I took. There is a tiny relay behind the steering wheel. Its a little involved to get to, but you either need to file the contacts which become pitted, or replace the relay with something similar from Radio Shack. I did the former in #880, and the latter in #1886. Both worked perfectly afterwards.
