EPROM chip by keydiver
Steve885
Concord ca
So I bought this gvr4..I haven't gotten it in the mail yet .(being delivered) its using a keydiver chip on 93 pump gas and really not sure what the prameters are set at..either did the seller he bought the car a year ago and never had time to really figure it out.. I'm running 91 what should I do..thanks for help
curtis
Clarksville TN
After the car shows up you can see whats on the car....IE air meter/turbo/injectors and you'll probably be able to give more information but if you can give us the car number and with some research you'll be able to find the old owner as well as info on the car. I haven't looked but Jeff's email address is probably under his sign on name. Keydiver...... damn I do miss him. Electronic genius he is.
Steve885
Concord ca
The car is 885 from Justin in Louisiana ..I'd pull over the link but haven't figured how to do it..Justin says it just needs a better tune..the work was done by a member ( vman911)
ktmrider
Tempe, AZ
KD usually put a sticker on top of the EEPROM showing the settings. Pop the ECU out and check when car arrives.
While the DSMChip ordering site is closed the forum is still active. It has an email for him, if the chip sticker is gone send a note with what you do know about the vehicle and any identifying marks you can locate. Fair warning, try to use a computer, manners, and "good" grammar. He left our scene for a reason but is still willing to help out from time to time.
