Engine/drivetrain build parts new/used/miscellaneous
T3mp0r
Erlanger, KY
Mostly BNIB 4g63 engine build parts. Without my life story, the project is no longer feasible for me. The prices are without shipping and PP fees. I will only do verified Paypal. Unless you want to come by, inspect the parts and pay cash.
AEM Trutime black 23-830BK x2 $200
Supertech Exhaust valves SUP MEVN-1007-8 $105
Supertech Intake valves SUP MIVN-1007-8 $105
Manley valve stem locks (32) $70
Supertech Valve guides (GDE-MI66-STE) x16 $60
BC Valve springs (BC0100) x16 $215
Manley Rods 14021-4 $325
2G oil strainer tube MD181210 $20
6 bolt crank 10/10 $50
6 bolt block (no oil squirters or ports for them) $200 obo
Spare head w/valves, springs, cams, caps, bolts. No gears. $150
FIC 750CC Low-Z injectors IS126-0750K $270
OEM MD156604 Timing belt idler pulley $55
OEM MD129355 Timing belt tensioner pulley $65
Spectra oil pan for 6 bolt $45
Felpro 9627 PT x3 $15 each
Transfer case output seal MR983368 $12
Driveshaft washer MT203641 x2 $14
Diff/Driveshaft/1G axle MA143517 nut x2 $10
Yoke sleeve MR470072 X1 $60 each
Flywheel bolts MD008839 x6 $18
Kiggly HLA pressure regulator 1205 SOLD
Rear main housing bolts MF140205 x5 SOLD
T case input seal MD723202 SOLD
Driveshaft carrier bearing MB505495 x2 SOLD
Driveshaft carrier bearing insulators MB505283 / MB505284 x4 SOLD
Aisin water pump WPM-012 SOLD
Gates blue timing belt T167RB1 SOLD
Balance shaft delete kit SOLD
Valve cover used SOLD
ACL Oil Pump OPMB1096 SOLD
OEM Timing belt tensioner MD164533 SOLD
OEM Timing belt tensioner arm MD130032 SOLD
6 bolt front case - unknown miles. The gears are straight cut. SOLD
Rear main crank oil seal housing MD040330 SOLD
Rear main seal oil separator MD040332 SOLD
Fluidampr 630701 SOLD
6 bolt crank (unknown mileage -uncut) SOLD
ARP Head stud 207-4201 SOLD
ARP Main stud 207-5401 SOLD
TopLine lifters LIF MI-6 x16 SOLD
Wiseco 1400 HD K625M855AP SOLD
Kiggly main girdle SOLD
Supertech Valve seals (VS-M6.63) x16 SOLD
