Engine Bay squeak
Muskrat
Lexington, KY
There's a consistent squeak in my engine bay, it seem more pronounced once the car is warmed up. I sounds like a belt squeak, but I've tried replace both accessory belts and adjusting the tension multiple times, and it hasn't changed.
What else could be causing this squeak?
Muskrat
Lexington, KY
Definitely sounds like it's coming from the belt side of the engine. Belt seem to be tight enough (of course, this is done by feel. I don't have a tension gauge), so I'm a little stumped..
mooserage
Seattle, WA
My A/C compressor did that, I would try taking the AC belt off and see if its still there afterward. If you have A/C of course...
-shamus
fivestardsm
Middle, Michigan
If its not your a/c doing it, then your next possibility would be the alternator, and then the powersteering. They could have dry bearings in it. If you do remove the alt belt, and the squeal is gone, then there are 2 possible causes, being either your alt or water pump. If that dosent do the trick, and you still have a squeal with no accessories spinning, then you could have a a bad bearing in one of your timing belt idlers/pulleys going bad.
Muskrat
Lexington, KY
More info:
Timing belt was just done, so hopefully it's not an idler or pulley associated with that. Water pump was done at the same time.
No A/C, so rules that out.
I'm going to try pulling the alternator and p/s belts one at a time to rule them out.
