Hi my name is cam and i live in denver... and i happen to the live in an area that does emission testing! i recently bought my first galant vr4 975/2000 and i took it in for the test and failed with the readings of...... HC GPM LIMIT:1.5000 READINGS:1.0418, CO GPM LIMIT:20.0000 READING 40.2977, NOx GPM LIMIT:3.5000 READINGS:0.6749
In my understanding it is running rich... i have an evo8 front mount& hard piping, tail bov, 3" MAF with MAF translator, and DSM link other than that it is all stock even the turbo
i was told to put a couple gallons of e85 that will lean it out but will it lean it out enough?! i also was thinking about putting a stock ecu back in it along with the e85, or should i leave the link in it and lean it out on that along with the e85?
if you guys could give me your input/hints/trix would be great!
THANKS.
CAM
THANKS.
CAM
