Emisión Label problem
galantrevolution
las vegas, nv
I have a JDM 1991 vr4 but the DMV here in Nevada want a emission label to determine if the car have an EGR valve since the lavel in the car is in Japanese, can somebody snap a picture of there emission label and also does somebody know where I can get more detail information for the vehicle specs for the Japanese market
fuel
Toronto, ON, Canada
Japanese VR-4 does not have EGR, and the emissions label is under the hood (in Japanese).
If your '91 JDM VR-4 originally was a 5-speed car, then it will be the 240hp Evolution model with big 16G TD05H turbo/larger intercooler&piping, 510cc yellow top injectors, close ratio transmission, 3.909 ratio 4-bolt rear (vLSD if E39A with 4WS, plate LSD if E38A RS without 4WS), hood vents, extra bumper vents etc.
FlyingEagle
THE Ottawa
What he said. ^^^ I took photos of the emissions label in another thread. Japanese Cyclones intakes have no provision nor did the Japanese market use EGR for emissions reduction.
You can add EGR by changing the EGR and swapping ECU's/rewire, but find out what emissions standards your chassis and engine (year of production) are held to when testing in NV.
I passed emissions idle and 2500 RPM (no rolling) test with flying colors, EGR does not come into play where it would make a huge difference other than visual, as a three way catalytic converter, clean plugs/wires and a working motor are all you need to pass the tail pipe sniffer as I proved years ago on 4g61t.org "passed smog thread".
I have a photo here in the Cyclone Dual runner thread I started a while back - how to kind of thing.
https://www.galantvr4.org/ubbthreads/showflat.php?Cat=&Board=newbie&Number=1142327&fpart=&PHPSESSID=
Credits due to this thread: Click me
FlyingEagle
THE Ottawa
Here are generic and oddly enough, Mitsu labels at autozones page:
Click me
The clearly show the shape and label for the EGR valve, which also clearly is not shown using the same shapes in the Japanese diagram. Japan did not have EGR on many if not all cars until much later on when they tightened up emissions. NV guy should kind of be getting this unless he doesn't see many JDM cars.
galantrevolution
las vegas, nv
The problem is at the DMV the smog lab must verify the vehicle then set the parameters for the smog but since the label is in Japanese can't read what the vehicle is equip with it, but thanks for the labels , I will post the results
