ECU
GVR4_1636
Active member
SANTA FE, NM
i took apart my ecu seeing there was a data cable poking out of it. found this.. there are points where soldering was done some of the data cable wires were ripped from the solder pionts (wasn't me).. there is a couple chips plugged in to the board and trans/resistors soldered in, but i have no clue what it is. just has the name rick on it.. maybe someone can let me know what this could be or have knowledge of this type of ecu build. thanks
