ecmlink help
EROCK970
Active member
new york queens
hey guys so i was using my ecmlink with my dell and it was all good. but then it took a crap on me so i went and got a mac book but now i cant seem to get it working on my mac. i got the softwear on my mac it opens and all but i cant seem to link to my ecm. has this happen to any 1 else
EHmotorsports
Beaverton
ok so if you have up to date software in your Laptop. you will need to update the software in your ecu. go back to ecm tuning and read up.
jnava
Arlington, Tx
dont forget to download the mac drivers. That happened to me as well. Download the mac drivers and you should be good.
EROCK970
Active member
new york queens
nope i did the mac drives still dont want to work for me. what dose it give you for your ports. my is saying some sh*t about bluetooth
EHmotorsports
Beaverton
go to the ECM links website it has all the info you will ever need. if you are not registered to the forums do so.
ade
Paumanok NY
i had the same issue
here was my solution
Thomas Dorris
Mar 11
to me
The following page explains how to get an account created on our user support forums.
Thanks,
Thomas Dorris
ECMTuning, Inc.
EHmotorsports
Beaverton
Also give it a little time since it is a holiday weekend and im sure Dave is on vacation. you posted yesterday.
also use the search function i just found a crap ton of info.
Captn
Did you do the firmware update on your ecu? Firmware Upgrade.
Or try a friends computer...
I had a problem not picking up any ports a while ago, I scanned for ports but it only picked something up when I took the cable out... Turned out the cable was bad.
Hope this helps some.
