eclipse gsx motor in vr4
I popped the motor in my vr4 and am swapping in 1 from an eclipse. do i have to also swap the motor mount brackets on the front and rear of the motor or are the eclipse ones the same as the vr4's. I ask b/c i cane get the mount holes to line up.
thanks
jeremiah
Struc
Oconomowoc, WI
I believe it depends on if it's swapping from an auto or manual DSM.
The front one is always different - you must swap that one. The rear, if it is stamped 195, is OK.
The front one should be stamped 344.
