Eclipse coilovers?
Ben
Lubbock, Tx
I'm sure this is common information that has been talked about, but I havn't mastered the search here and don't see anything.
My Galant has everything from a 92 laser underneath it. suspension, subframes, rear end axles, knuckles, brakes and all. I am about to start looking for coilovers. Would I not buy coilovers for a 1g AWD?
turbohf
Lake Stevens, WA
good question. and i wanna say that the strut tops are different mounting. but not 100% on that...
also for the search:
-re:
Eaglesfly
St. Cloud, FL
Quoting Ben:
Yes, for sure the upper mounts are different for the fronts. The Galant has the strut hat 90 degrees offset from a DSM. I'm currently working on making mine work by drilling out the third hole in the correct spot (the one that normally has the black rubber plug in it).
Ben
Lubbock, Tx
Could I adjust that out? Right now the front sits really high with the laser suspension. So much that it has a lot of positive camber and it gets worse when it squats
Eaglesfly
St. Cloud, FL
Quoting brunoboy:
1g top hats and our top hats are the same. rears may sit funny due to the height difference of each car.
Incorrect. If it is a true coilover with a pillowball upper camber adjustable mount, they are NOT the same. The VR4 plate is 90 degrees offset from a DSM. A conventional strut however will bolt right in.
Ben
Lubbock, Tx
Would I need to buy galant coil overs then?
I saw somethign about a ksport group buy, but I'm sure that's long gone.
Leon_R
Chelmsford, MA
I have used DSM coilovers on my Galants in the past, the only funny thing I remember was the rear spring adjustment, it was "fully out". It was OK in my case, but if I wanted it any higher, I would not have been able to do that.
This has been so long ago, that I do not remember if these were JIC or AGX... Probably JICs because they have shorter bodies for lowering DSMs.
Ben
Lubbock, Tx
The difference in the upper mount may explain why my camber is the way it is in in front.
was it still low and you might want to raise it a little? I don't want it too low in the back becuase I have kind of a tall slick and this thing is going to squat.
By your second comment, I'm assuming it was on the low side.
Ben
Lubbock, Tx
Do galants normally have 4 holes at the top of the front strut mount? In that body that is. Mine does
Ben
Lubbock, Tx
Ok, I wonder if I can use the galant coil overs with the eclipse knuckles....
I just need to call Ksport and see what they say. hopefully they will be able to help me out.
