Easiest method for removing dash...
324vr4
Bozeman, Montana
My damned gauges are all sorts are wired weird and I am going to remove the dash and wire them all up properly so that the dimmer on the dash doesn't make some turn off, some go dim, and others get extremely bright....so if anyone could please share with me the easiest and most non-destructive method for removing the dash I would be grateful!
BoostedAWD91
Danville,Pa
just remove the underdash and the dimmer switch and the other switches u need to and u should be able to fix all the wiring for the gauges without removing the dash
324vr4
Bozeman, Montana
Noted, thank you BoostedAWD91...I tried the search function but it ended up saying no results found...Will peruse the How-To threads and get more advice...thank you!
I typed +dash +removal into the search and came up with two pages of results. The how-to was on the second page. /ubbthreads/images/graemlins/dunno.gif
dash removal
324vr4
Bozeman, Montana
Well apparently when typing dash+removal it doesn't work the same...and after the previous post to mine I found it in the How-To section...thanks
