E85 to pass emissions?
Hey guys, I have a question (havent had one forever, Im long overdue)
Has anyone here run a 50/50 e85/gas mix or straight e85 to pass a dyno-emissions test? My car has a bad cat, It was in the car when the previous owner blew the engine and turbo, and that much oil destroys catalytic converters, theres no way its good. Ill probably replace the cat, but if the e85 idea works, ill do that as well. Thanks
Ryan
Andy_S
Shithole Wisconsin
Tried it and it doesn't work. Leans out the car but then your NOx goes up. Just buy a $60 catco cat from summit, clamp it in for the test and you will pass with flying colors. That will get you by even if all other emission components are removed.
JNR
ca
I hear 87 octane is wise to use on a smog test and be sure to drive the car for awhile prior, so it gets nice and hot (cat). The hardest part for me is going to be the visual; all because I don't have an oem air filter box /ubbthreads/images/graemlins/banghead.gif
Yao
Denver, CO
Funny you posted this, I was at the Emmission station last Sat. trying to pass with full E85 with only Jeff's chip and NO way of Tunning. All I can say is ALMOST!!! my HC failed me at 1.9 and the limit is 1.5. They even showed me the graph or area under the Curve(limit) and the entire test the car stayed under the curve*way under the curve until he ACC. everytime he would ACC. the HC, NOX CO would skyrocket.... I think Jeff is a little happy on Spooling the turbo. Anyway, I have until this SAT to do another test so my 25 bucks wouldn't go to waste. Because of this incident, I have decided my Eclipse would get the Speed Density sooner then I anticipated and I have since moved the E-manage from Eclipse to my Galant and have been playing with it all week. As the way it sits, I have 20% less fuel accross the board below 4k and it would still drive with no ill effect on Jeff's chip. I will let you know this SAT if I pass or not with E-85 /ubbthreads/images/graemlins/smile.gif
Im not throwing a piggyback on this car to pass it.
Ill just have to get a cat, ugh those bolts are probably so rusted on...
I'm intrigued to see if you pass or not. I'm in Michigan, so I dont need to worry about emissions, but I always like to know more about the greatness of e85.
from the looks of it though, like others are saying, the NOX and such will go crazy, but with some tuning I'd like to see how much better it does.
Yao
Denver, CO
/ubbthreads/images/graemlins/smile.gif PASSED with flying color. Mind you this is Full E85 on Rollers here in colorado. Numbers are as followed:
HC PPM 76.8 Limit:220 PASS
CO% 0 Limit:1.20 PASS
CO2% 9.7336 Limit:12.0653 PASS
NOX forgot /ubbthreads/images/graemlins/frown.gif
This is on Stock bottom and top with HKS 264cams/850cc/3"cat/E-manage/e-85/FP18 and no other emmission equipment on the car with 150K /ubbthreads/images/graemlins/smile.gif
Incidently, there is a Honda HX side by side with me when doing the test and guess what, he failed! and I pass /ubbthreads/images/graemlins/smile.gif
