E-Brake cable routing?
Scase90
Saint Robert, MO
Im in the process of rebuilding my vr-whore and im trying to install the E-brake cable but having a hard time routing it underneath the car /ubbthreads/images/graemlins/confused.gif
If anybody has any info or pics of e-brake cable on there car it would be much appreciated. thanks
RedTwo
New Zealand
Did someone else remove it? You need to get between the heat shield an the driveshaft tunnel, which requires the drive shaft and exhaust to come off. There's a few M6? bolts holding the tabs down. At the back of the car there is a vertical section before the rear subframe the cables split up and run along this, then onto the trailing arms.
