DTC 0021
SoJerz168
New member
92 Galant VR4 168/1000
Link v3 SD
Coolant temp reads -74 constantly.
Have a CEL
0021 code
I installed a New sensor, cleared codes and CEL
comes back on after a couple minutes.
Yellow/Green wire & Green/Black wires both have continuity from sensor plug to ECU plug.
Anybody have ideals?????
thomcasey
Indianapolis, IN
That issue is all over this site (and DSM sites). Look at your wiring to the Coolant Temp Sensor on the thermostat housing. Either a disconnected connector or broken wire.
ajsmith279
New member
Link v3 SD
Have a CEL
0021 code
Any luck on figuring this out? Mine constantly reads 74 but will spike up and down quickly when revving the engine. New sensors, all wiring specs out correctly. I'm wondering if it might be an issue in the ECU.
