dsm link clutch cut question
yeti
san diego california
Do i use the clutch switch that gets pressed when your foot is off the clutch or do i use the one that gets pressed when you push the clutch in.....
the one that gets hit with the clutch pressed in is gone the plug was clipped from the wiring harness.. and the other one is the one that controls the cruise control...
it says to cut the green/black wire i see NO black/green wire i see green/white wires and geen wires going into the cruise control switch
