alansupra94
Well, I need some help regarding running a stock non-eprom ECU with this setup.
I have a built motor finally going into my VR4 with the follow specs that are not the same as stock:
- JE piston 8.5:1
- Crower Stage 3 Camshaft ( 280280br>Dur @ .050: 218216br>Lift (in): .422"/.418" Lift (mm): 10.71/10.60)
- MHI EVOIII 16G turbo (Stock Boost)
- Walbro 255LH with Aeromotive FPS (I figured I should just throw it in there)
Will the stock ECU be able to handle this? I just wanted to run this setup for a little to break in the motor without having to worry about tuning and problems.
Thanks,
Alan
- JE piston 8.5:1
Thanks,
Alan
