mooserage
Did some work under the car recently and was inspecting things for future work, one of which was installing torque solutions carrier bearing driveshaft bushings. Looking at the rear most passenger carrier bearing mount I found this gem:
I've had this car for about 70k miles, so I guess it was this way since then at least. Anyway, I could see that some of the threads were stripped or cross threaded even with the second nut covering it up. Pulled the lower nut off and found this:
For fear of the threads coming off with it, I left the upper original nut on there. So, I have a few questions and I'm hoping wiser folks might have some advice for me before taking the other nut off to install the new bushings (the originals are shot). I searched a bit, but didn't find much for this issue.
-If I install the bushings and I can torque it to spec (FSM: 22-29 ft/lbs) is that good enough and I am overthinking this?
If the threads are really damaged after removal:
-Besides chasing the threads, is there anything else I can do to "fix" this if there is still enough threads left to make this work?
-Can the studs be replaced? (I think not from the FSM, but if anyone knows otherwise it'd be good to know)
-Could it be reinforced in anyway, like sleeved?
Despite the huge mileage on this car, it spent its entire life in Washington except for one winter in the midwest, but there are still a lot of signs of corrosion under there /ubbthreads/images/graemlins/frown.gif I was just thankful that most of it is on the surface.
Thanks!
Thanks!
