drivers side glove box
curtis
Clarksville TN
I found a 89 Galant in the junk yard last fall with a small glove box panel next to the drivers left knee. I purchased the whole panel with flip open box for five dollars. its the same color as the old panel and is flat instead of a bulge toward your legs its a direct bolt in except for two steel brackets that have to be removed and make sure you get the air tube because its different. Makes a great place for boost controllers and afcs. The beautiful thing is that it can be closed and no ones the wiser great for the 4 door sleeper
curtis
Clarksville TN
afc1.
Yeah, when I rode with you, and you turned the boost up, I was wondering where my little driver side dash was.
But now I know.
467
Royal Oaks, Ca 45 min S of San Jose
Yes, any Galant with the manual seat belts will have this glove box in the drivers side kick panel. Don't forget about the pass side box too. Its a few pounds lighter. You do have to worry about color. There are some blue and I believe brown interiors out there.
Ward
quote:Originally posted by 4orced4door:
That's awesome! Perfect place for my new VPC...
Were all the '89-ish Galants equpped with this glove box?
4orced4door
Raleigh, NC
I hope my VPC cables are long enough to go from the far left to the far right of the car though. Might have to put it in the center after all.
Hertz
Chicago, IL
That kicks ass. So it mounts in where we have that 1"x6" snap out panel?
What do you suppose the actual purpose of that piece is? Fuse box?
