Driver side back floorboard has water in it.
misfitsnemesis
bristol TN
My car has been setting for about 6 months now outside. Its a sunroof car. I noticed last week after it rained the back driver side floor board is soaked.It seems to be around the start of the c piller all the way back to the floor board. I went today while it was raining and same thing the back floor board is getting water in it. There was no sign of leaking any where. The seats are not wet,headliner has no sign of water damage or any where else just the back driver side floor board. Only other thing I can find on this was this post click .
Any help would be great.
G
zompton
Your going to have to remove some panels and have someone run a water house around where it may be leaking while your inside the car.
Wizardawd
Franklin, NC
Open the sunroof and check the drain ports. Sounds like one is clogged and is over flowing water inside. May have to remove the headliner to get to the clog.
Wiz
misfitsnemesis
bristol TN
Thanks for the response yeah everything is pointing towards the back sunroof drain being clogged. Going to pull some stuff and check tomorrow.
