dome light stays on even when door shut??
3rdstrikedsm
32159, FL
But the door open light on the dash indicates no doors are open so if I shut the light off manualy it will shut off.
So just when the button in the middle is on it wont shut off when all doors are closed.
I am at a loss.? /ubbthreads/images/graemlins/uhh.gif
strokin4dr
Savannah, GA
I'm not sure about the dash light not coming on when this happens, but my first thought would be to check all of the door switches. You can even pull the rubber boot off, remove 1 screw and unplug them to eliminate them as a possible problem and then check to see if it still happens. Good luck.
-Ryan
3rdstrikedsm
32159, FL
I have checked all of them and they are for sure good, I am thinking it is etacs as people have mentioned in my other wiper thread.
