Do EVO 8 valves use stock OEM VSS?
matt92vr4
Venice, FL
Hello, I'm placing my order today for all of the parts to rebuild my motor. I'm putting in EVO8 valves, springs, retainers etc and just wanted to make sure I still use the stock OEM valve stem seals from the Galant. Thank you in advance for your help.
-Matt
4thStroke
Vancouver, WA
I believe they are all the same. I threw in the same stem seals that they were throwing in the Evos, but be sure to use the correct color of seal for each side of the head.
