Datalogger cables
eviLntt
Santa Rosa, CA
I don't have one myself, but I was wondering how complex are these? I make serial cables all day long at work, and have access to all sorts of eletronic supplies. If they aren't too complex or require any special parts I would be willing to put some together for a low price (cost of materials plus a few for my time). Any thoughts on this?
DarkDevilMMM
Vacaville, CA
there are 2 different kinds of cable out there, 1 active, 1 passive. active one is a bit complex, but not hard at all. the passive one consists of resistor and diode. let me see if I can find the drawing again... I posted this before, should be in How to...
eviLntt
Santa Rosa, CA
If its just a resistor and diode, thats really easy. I just need a drawing or one that I can inspect and I know I can figure it out.
eviLntt
Santa Rosa, CA
Well the passive is stupid easy, the active would require a little more brain power. I could do both... what is the advantage of the active over the passive? Is there anyone that would be interested in this?
jepherz
KC, Missouri
I think the only reason to have an active cable is if you have a 92+ car. If you leave a passive cable plugged into these cars, they have an ABS diagnostic computer that will disable the ABS if the cable is plugged in (Grounding the data pin) at start up.
I believe the active just allows you to keep the cable plugged in without it tripping the ABS. AKA "Auto-On". These used to be on ebay for $25 but I've not seen them for a long time now.
speedyvr4
miami, fl
I hate wiring and I made one. If you have all the tools at work,and you do that stuff everyday, it shouldn't take you more then 10 minutes.
stevep
St. Charles, IL USA
The passive cable depends on your computers serial port accepting non-complient RS232 signals for it to work. The standard uses + and - voltage levels for signaling but the ECU output only goes from 0 to 12v. So the passive cable might not work with all computers. The active converts the single ended output from the ECU and converts it to dual ended signals the meet the RS232 spec.
You can tell an active cable by it's need for a power source.
Auto-on is a whole different thing. That refers to hos pin 10 gets pulled low to activate the datalogging mode on the DLC.
