Specter
There is this sound coming, as if something is rubbing against the other, it only comes when the engine decelerates, not at acceleration. There is no sound at idle. The car runs perfectly fine. The Clutch is perfectly fine. The engine is a 2g, it starts so the crank sensor is fine. The rubbing sound only comes at deceleration. And when you crank the engine, there is a hammering noise when the starter cranks the motor. I showed it the 2-3 guys and they are saying that its the flywheel, either that its coming loose, or its having some play. The engine is bone stock and with fairly low miles. What do u guys think?
