Crank pulley rubbing on timing cover
AuSpecVr4
Brisbane, QLD
Hey
I have bought a new timing cover when i built my 2.4l (Balance shaft eliminated) and i have some serious rub marks in my new timing cover which has almost made me consider buying a new one. I found this on JNZ tuning. Crankshaft sprocket spacer I still have my balance shaft belt on and rotating but theres no shaft. Do i need this spacer to space out my pulley?
broxma
San Antonio Tx
No you shouldn't need that, just leave the old balance shaft sprocket on there. If the crank pulley is rubbing on the timing cover, it's not seated all the way down, or the highly unlikely, the pulley is bent, but I've never seen or heard of that. Often times I find people have put incorrect length bolts into the timing cover. This means the bolts tighten down, or bottom out essentially, but the cover still has some free play in it off the block, so it hits the pulley. It's hard to notice when you put it back together.
/brox
AuSpecVr4
Brisbane, QLD
It's strange, i have checked the timing cover and its bolts and theres no movement, i separated my old crank pulley (Luckily in the driveway starting) it could of been the outer moving back and forth on the old cover because when i pulled the old one off it basically could fall straight through the middle, i now have a light weight aluminum crank pulley on it and i checked the back of it and the paint hasnt been touched so i guess i learned that if your building a fresh motor and new timing cover, replace your dampner.
mikus
Aurora IL
^ I'd agree with your assumption there. when they seperate, they'll 'etch' the cover and eventually can cut through it.
galant344
oakforest il.
good thing you caught it before the outer ring ate all the way through to the timing belt. cheaper to replace the lower cover and damper than pulling the head and replacing the valves!
AuSpecVr4
Brisbane, QLD
Yes all true i've seen some damage pictures here, now im up for a new timing cover because it has almost worn through, but first priority is get the motor and box back in the car so i can get the thing running again.
Cheers
