Coolant temp sensor
mcbride89
Belmar,NJ
So damn frustrating that these sensor bite the dust so easily. I just replaced 2 within the last 4-5k miles and now going to vato zone for another. The resistance on one in there was over 5k. This one I had laying around I thought was good, was 4k.
I'm guessing they just make these like sh*t. And I seriously just put a new 0
O2 in there. Went to thinking how could I have messed plugging a connector in. Check the CTS and sure as sh*t it's out of spec -__-
Just wanted to hear others input on this
mcbride89
Belmar,NJ
I'm calling mitsu tomorrow. I tested this one in store, tested fine, put it in. Won't start. Check it again, 5.6k... I think it's whatever under the plug and has a shitty connection after you apply any torque on it. Autozone is going to have another for me tomorrow. But after this I'm just going to order a new OEM unit. I'm getting annoyed of pulling and cleaning the plugs after every time I crank the car trying to get it to start.
mcbride89
Belmar,NJ
Agreed, or 3 or 4 times -_-
31 bucks through jnz. I'll give them a ring in the morning.
I've never even had to replace one. The wiring leading to it, however, has required some work over the years.
mcbride89
Belmar,NJ
Yeah mark, the wiring feels brittle for sure but I do have 4.7 bolts with key on there.
I looked into it more and cases where it's piss cold like it is here in jersey, 32 degrees = 5.3ish K. So the sensor is okay. I thought they only went to 2.5, but that's when it's about 68 degrees out.
