Coolant leak... Heater?
While i was driving along the other night i smelt the foul smell of coolant in my car... I still can. Cant see in visible leaks in the engine bay, and the smell is only inside the car. Im definitely loosing coolant, but cant seem to find any wet patches inside the car... I've recently done a coolant flush, could this have caused it? What exactly could be the problem? Oh its a 1995 Mitsubishi Galant Sports GT VR-4. Cheers /ubbthreads/images/graemlins/smile.gif
Potentially, if you used any pressure to clean out the system, you may have opened an already weak spot in the heater core. Likely the leak is small since you can smell but not see it, or it is running under the carpeting and soaking in the insulation material beneath.
Either way, you need to fix that. Stuff will fog your windshield all the time.
How much would i be looking at to get it fixed? Would it be a whole new heater core, or maybe just a hose?
slobra
Wilmington, De
I just recently replaced the heater core in my galant and I got one really cheap off a member on here. I replaced it myself and the easiest way is to take out the dash and take out all the hvac components.
It may sound like alot but there is a thread in the how to section on how to take out the dash and its pretty easy. If you decide to do it and you need some help just PM me and I'll give you some pointers.
EDIT: I just saw your car is a 95. Still, if its anything like an E39A, it'll probably be easier to take the dash out.
