CM Performance Exhaust
I am considering a CM performance exhaust for my Galant. I currently have a Megan Racing O2 housing on the car. Is anyone running a CM Performance exhaust on their car using this O2 housing. If so, did it bolt up good or did you have issues with it fitting. Thanks
I have it an love it!!! I have the E3 O2 housing though. But the exhaust is A++.. I have the single 4 inch tip system. /ubbthreads/images/graemlins/grin.gif
2.5" Opening on Two-Bolt flat flange is compatible with most Downpipes as well as OEM
Quote above was taken directly from Meganraging.com website. This means the answer to your question is yes, the cmpe exhaust will fit. Pick your system & contact me so I can make sure you get the discount. You have to order it through me in order to get the discount /ubbthreads/images/graemlins/wink.gif
