clutch pedal switches
so im trying to wire up my aem for the lauch settings and need to know the wiring for the clutch. (i was told there is 3 wires)
Which wire do i ground to dis-activate the engage the clutch to start
and which wire is ran into the aem for an input?
jepherz
KC, Missouri
There are two clutch switches on our cars. In order to be able to crank the car without the clutch pushed in, just unplug the switch at the BOTTOM of the clutch travel. You'll want to use the one on the top of the clutch throw for your AEM setup. What is the AEM looking for? Ground when clutch is depressed?
