clutch pedal engaging
Snook1345
Active member
Baltimore, md
watsup guys, so finally got 747 started up yesterday and as far as the motor goes, besides needing a tune, it is running pretty good.
few small issues
1. the clutch pedal engages like a pubic hair out from the floor, did switch to after market clutch but from the small things i have read that isnt the problem. Thinking i may be able to just adjust the pedal
2. 2 of 4 gauges randomly stopped reading while warming up the car at the exact same time. Boost/Oil Pressure, going to chalk that up to an electrical issue and trace the wires and check sensors.
It is like 20 degrees outside so not a damn thing is happening today, just trying to get some info on the clutch issue TBH, trying to get it to the shop and on the dyno Monday
tektic
ronkonkoma, ny
I had this clutch issue over and over. It went away by accident one day. The pin started to fall out of the lever that pushes on the mc and when I was mashing furiously in traffic on the grand central parkway I think I knocked air out of said master cylinder. When I pulled over and replaced the pin the engagement point was up 2" from the floor. With that said I think it 1000% necessary to extensively bench bleed any new master cylinder. I don't have any other explanation as to why mine works so well after having given up on it. I blead the slave over and over again with no noticeable change. I eventually used a smaller bore for extra throw and this did help, but have since swapped back and still have a good point of engagement.
