climate control ac
tintoy
philippines
Need help. When my battery is diconnected and connect it again turn on the key the ac is automatically on, that is normal. But resently i experience a few times, i did not disconnect the battery turn on the ac is automatically on. Any of u guys experience this problem? /ubbthreads/images/graemlins/confused.gif
tintoy
philippines
Il check on that. The problema started when I had a bad battery. Now a have a new battery installed .
MX4
New Zealand
I bet you have an aftermarket stereo in the car. When people install an aftermarket stereo they often accidentally cut the "memory" wire for the air condition, as the wires are in the same part of the loom.
OK, there should be two blue wires on the stereo loom that arent connected up. One of them you need to connect to the red & black wire so its gets a constant 12v feed. You will have two try both blue wires to find which one it is. After this your climate control will work perfectly.
tintoy
philippines
Tap the blue wire and disconnect battery connect, turn on see if the rigth wire? If not try the other one?
MX4
New Zealand
Tap one of the blue wires into the red/black wire that powers your stereo. So then the blue wire is getting constant power whether the car is running or not.
