moduleunknown
Sections of the Chassis harness on my gvr4 are trashed. For example, all the wires that connect to the alternator are trashed, covered in dirt, oil, grease. Loom was not present in that area, wires were hard, insulation torn in sections, just overall bad.
I'd like to replace that section of the harness, but my concern, if I hack off that section of harness and reattach a good section - the double white wire from the alternator that runs back to a 100A fuse, how should I splice those wires back together? Can I solder them or is that a bad idea? I started thinking there's a good bit of current running through those wires. Would that affect the solder? Do those wires get hot, and would solder increase resistance causing them to get hot? Could the solder melt? Would I be creating a fusible link there?
What is the right way to fix those wires?
