Charging system
kwmcneil
Member
cookeville, tennessee
My charging system has stoped working on me, im getting 15v to the relay lookingDiode box, and if I take tjat diode box out and put a jumper on it the battery charges but if I turn the key off the engine keeps running, I baught a new diode box and it still did thd same, I took the new and old boxes apart and resisyance is the same acrosd both blocks an diodes(47 ohms across the stones and 5.3 megaohms across the diode does anyone have any idea whats going on?
kwmcneil
Member
In the fuse/relay block under hooh the "relay" marked alt, i took the cover off this "relay" and therse a diode and what looks like a ballast, where is the alternator fuse?
grocery_getter
In that same fuse box there is a rectangular fuse with the clear cover that is installed diagonally in the corner. Its 2 feet are bolted on with 10mm bolt. If that fuse is bad the alternator is not going to charge the battery. Before you work on the bolts, disconnect your battery first.
