Catback Exhaust
Alright I'm sure this has been posted a ton of times, however I've spent 2 hours searching and I don't know if it's my wording or what, but I can't find anything on exhausts. I'm buying a GVR4 and it needs a new exhaust (OEM is rusted through) and I figure I may as well upgrade while replacing it.
That said, what are my options for an inexpensive, 3" system?
Jesh
Soldotna, Alaska
Off the top of my head, these are the places I know of that make a vr4 specific exhaust.
www.cmperformanceexhaust.com
www.tunersnation.com
From what I can tell it appears to be the same product, But don't take my word for it. And as far as inexpensive, I'd say go to your local muffler shop and have them make one. probably won't be as good, but it all depends on what you wanna do with car.
524of1000
San Antonio, Tx
Those are the same exhaust systems. Some other options would be a 2g AWD downpipe and a 1g AWD catback combo. It should be noted however that it may require some modification to fit and you will still need a cat or test pipe.
We sell CM Performance exhausts. If you order it through Tuners Nation you get the board discount as long as you use code GVR4ORG. I've worked with CM Performance over the years to really customize it & make just about every option available for our cars.
