Car won't start
alik
Boston, MA
Cranks fine. Will start with some brake cleaner sprayed in the TB, and will start after being run for a little bit. But let it sit (even for 20 min), and it's back to the drawing board.
Air ducts are tight. Fuel is there. Ignition pulse is good. Spark is present. The only thing is, the bundle of sensors near the water neck is MIA (cracked wires, broken connectors, in the process of searching for a replacement).
Help, please.
AnotherNewb
Orlando, FL
That bundle of wires near the water neck, one of them is the coolant temp sensor to the ecu. Fix it and you'll fix your problem. A proper search will show you a diagram.
