Griffin5505
Member
Hello, I picked up 1025 about 3 weeks ago. When i first got it there was no boost until about 6000 rpms (manifold was cracked, bad gasket and 5 broken studs). I swapped in a 2g manifold and put on new studs and so forth. While the car was down I put on new spark plugs (bpr6es) with wires. After the turbo was back in I took it out and it will not go above 3000 rpms in any gear /ubbthreads/images/graemlins/banghead.gif. I have already checked the cat and it is fine. While the clutch is in I can rev the car to 4000 and drop it, I feel the torque that wasn't there before. But as soon as it hits 3000 rpms is just feels so slow. I have tried switching the old plugs and wires back in and it still doesn't make a difference. Before the turbo was off it ran fine. Also it is completely normal feeling up to 3000.
Any help or ideas would be great.
Thanks, Ian
Thanks, Ian
