Cant find it.........
Diego
I tried searching and i cant find what im looking for. Im looking for the directions on how to re-time my motor with picures so i know that my marks are all there.... cause im sure ill need the pictures to go along with it... TIA
Diego
gvr4ever
central Indiana
The directions are on vfaq.com
Just make sure to ground the diagnostic port on the fire wall. I like to use a whiteout pin on the timing marks. Take the pass tire off and mark the crank, then 5 on the timing guide.
A couple of tips. Make sure everything is warmed up, but make sure the fans are not on, power off the radio, everything. Make sure the vacuum to the FPR is on after a hot start, if you shut off for any reason.
frank1
anaheim
Quoting gvr4ever:
^^^^^++++1
