Can a tire alignment fix this?
desant78
Clarksboro, NJ
Hey Guys
I am just a few days from finally putting 1662 on the road and continuing the testing/repairs on her. On thing I noticed is the camber seems really off....and I was wondering if the alignment can fix it. I understand I do not have any pictures, I will post some eventually. I am simply asking right now if camber is fixed, or if it can be adjusted.
the problem is noticeable positive camber...so much that it is visible.
Once I run 1662 and all seems well, is it worth taking to a place to get the tires aligned? -that is what I am really getting at with this question.
thanks in advance!
DR1665
Iowa City, IA
You should definitely see about getting the car aligned. Expect them to advise you there's something wrong, and offer to take care of it for you for about 4X what it would cost you to DIY, but it's peace of mind to have those numbers.
iLLeffeKt vr-4
NYC
From the factory camber is not adjustable. Unless you have adjustable camber plates or offset bolts the alignment won't fix it.
Did you check the controls arms/frame to see if anything is bent? Did you or previous owner hit any curbs with it?
My fronts had pretty bad positive camber then before I did the alignment I went to kragen and got a set of adjustable camber bolts for the front and that solved that issue. They couldn't do sh*t about the rears though
desant78
Clarksboro, NJ
Quoting iLLeffeKt vr-4:
unfortunately this is my first vr4/dsm/car really i put some serious work into. The wheels weren't bolt on, and had wrong rims and was told the camber was due to that...being a total newb I believe him. Now with vr4 rims it sits HORRIBLY.
then doing more and moer looking under 1662, notice she was banged up everything! did a carfax(ALWAYS DO THIS) and found out she had been in an accident in queens. but the car was driven for 3 more years after that.
so i guess i'm in search of camber plates now.... /ubbthreads/images/graemlins/uhh.gif
desant78
Clarksboro, NJ
if all i need is a camber plate I am VERY tempted to attempt to fabricate this myself....
does anyone have dimensions for the plate? and if I have the camber plate...i can use any shock/spring correct?
belize1334
Bozeman, MT
Camber plates won't do much good unless you have coilovers because the stock front spring is too big to move very far inside the tower without contacting. Don't bandaid the problem. Fix whats wrong and then use camber plates if you're looking for something beyond stock capabilities.
