cam degreeing issues (resolved)
Mn92gvr4
North branch mn
so I have a set of crower (not brian crower) cams. "stage 2". intake cam degreed out perfect but the exhaust cam is kicking my ass. Crower tech help has been able to confirm that I do in fact have the correct product but has been completely useless in every other aspect.
My spec card says it is suppose to open 36.0 bbdc and close -4.0 btdc (aka atdc)
I have solid lifters in the first valve. Is this not the correct one? If so wth is going on or what am I missing? /ubbthreads/images/graemlins/banghead.gif
MuffinMan7580
Fort Bragg, NC
Yes, solid lifters go in for cylinder #1. What is kicking your ass?
If I understand how cam degreeing works, you should be showing .040" of lift at 144 degrees, and then .040" of lift at 4 degrees (according to your degree wheel). That's a total of 212 degrees of open valves, you should have max lift @ 250 degrees.
BTW, I've never degree'd an engine, just watched a few instructional videos. Please post up what the actual measurements turn out to be.
Mn92gvr4
North branch mn
Ah I see I left a part out of my first post. I was reading 17 degrees off on opening and 14 degrees off on closing.
Today i tore everything down and started the whole process from scratch. This time i came up with much better numbers. not sure where i went wrong the first time thru but some thing must have been screwy. this time i got 29bbdc on opening and the card says 36bbdc, closing is 11atdc snd the card says 9atdc. just goes to show always double check and take your time.
donniekak
surprise az
Most cams are spec'd at .050" lift. I always use the centerline method as well. There is an online calculator.
