Build Questions
The_Big_Weave
Rapid City, SD
Looking to rebuild my motor, so I need some questions answered. Long story short, blew a ring landing and don't have the money to pull the motor and have it bored. So I am just re honing the cyl walls and then putting in a new set of Topline 8.0:1 pistons and rings. The question that I am having is that I replaced a cyl. and a rod from a donor car a while back with about the same mileage as me.
1. I was wondering if I should try and get my orignal rod back from a friend that is very hard to get in touch with, or do you think the donor rod will work? Put 1900 miles on the donor piston and rod and never had a problem? How do I know if they are off balance?
2. Also I am replacing the rod bolts with arp rod bolts anything different required to you these on stock rods?
3. Last question should I order ACL race bearing or are Topline rod bearings fine?
And any tips that you can give me on rebuilding my motor from this point.
thanks, weave
iLLeffeKt vr-4
NYC
Why don't you get some 2g pistons on 1g rods? I'm not a fan of Topline so I say go with ACL or Clevite for bearings.
Bearings are relatively cheap, so go with the best (such as ACL, Clevite).
If you're going to use ARP rod bolts it would be best to have a machine shop install them and have the rods reconditioned and balanced at the same time. They will make sure the big end of the rod is perfectly round after installing the rod bolts to the proper torque. It's not expensive. And if you want to use 2G pistons on stock rods, its the perfect opportunity to have the shop resize the small end for the 2G pistons. That's not expensive either (despite popular belief.) And if you want to be really precise, use a rod bolt stretch gauge when you put the rods in, instead of a torque wrench. It's the more accurate way to tighten rod bolts and ARP recommends it. I bought a decent stretch gauge from Jegs a while back, but I can't remember how much I paid.
The_Big_Weave
Rapid City, SD
I looked at putting 2g pistons on and it was about 200 worth of shop work, I would rather just put brand new pistons in also. I have the pistons already so I cant got second gen pistons. Also you think I should get the rods balanced and reconditioned? Is it ok to just use a torque wrench on rod bolts or will I see problems with ARP rod bolts. I will order ACL bearing tonight.
Kenny_Kline
Seekonk, MA
If you use ARP hardware on the rods, you will need to have them machined. Then you will need to have pistons pressed onto the rods then have them balanced.
Put in new bearings/rings, torque to spec, and call it a day.
Why not drop the block off at machine shop? Are you doing an in car rebuild? If so, your going to need to measure ring gap compared to the new rings to see how much, if any, has already been taken out to gap correctly. Also, you need to atleast ball hone the cylinders.
The_Big_Weave
Rapid City, SD
I might get flamed for this but I am doing the build in the car. took oil pan and head off already and have pistons out and honed.
