braking issues...
spoolintsi
Member
Traverse City, MI
ok guys, so my fiance and I just bought a house and its slightly up on a hill. When i back down the driveway my brake pedal feels like it kicks back at me and the brakes seem to almost skip. I'm not sure the issue because when I'm going forward this has never happened. Any ideas? Like I said it only does it when backing down my driveway, and there has been no braking issues before. Thanks in advance!
coyotes
Seattle, WA
maybe ABS is screwing up, do you have 17s or larger? Wouldn't hurt to make sure the sensors are clean.
fuel
Toronto, ON, Canada
Quoting spoolintsi:
Mine does EXACTLY the same, whenever a reverse back down a driveway on an incline it trips the ABS momentarily even on just relatively light brake pedal application. I can feel the pedal kicking back a couple times and hear the ABS motor kick in to action.
My car is stock with stock wheels with slightly larger 205/60 R15 tyres fitted. The ABS doesn't have any warning lamps coming up and still functions fine when I have braked heavily enough for it to kick in.
unplug the abs unit for now. Delete it when you have a chance. The ABS is junk on our cars. Practice threshold braking in some dirt or snow and you'll stop better than the ABS ever will. The ABS is very well known for causing issues such as this even on a perfectly good system.
