Brakes: rotors, pads, lines, etc
collected brake information on brake pads, rotors, lines that are specific to galant vr-4s.
Info:---------------------------------
our brakes (GVR4) are the same as the 93-94 1G DSM "Big Brakes", 2 piston calipers (front) and larger rotors, 4 bolt pattern. if you buy regular rotors, technically they will fit, but only about half of each brake pad will actually have contact with the rotor, this is dangerous
GVR4 Rotor Dimensions (diameter x thick)
Front
276mm (10.9in) (10" 55/64) x 24mm (.94in)
Rear
265mm (10.4) x 10mm (.39)
Brake Lines:
Stainless Steel
$130 - http://www.diamondstarmotorsport.com/brakeparts.shtml
$115 - http://www.roadraceengineering.com/eclbrakes.htm
$185 - http://www.dsmparts.com/customer/home.php?cat=14
$162 - http://www.machv.com/brstbrli.html
Rotors:
$7.79/ea/re - RAYBESTOS PG Plus (see note)- http://www.rockauto.com/catalog/catalog.php?carcode=1206212&parttype=1896&partGroup=14&EPImodelID=5589&EPIengineID=2327
$15.83/ea/fr - RAYBESTOS PG Plus (see note)- http://www.rockauto.com/catalog/catalog.php?carcode=1206212&parttype=1896&partGroup=14&EPImodelID=5589&EPIengineID=2327
$55.65/ea/fr - Mountain - http://www.stopshopanddrive.com
$190/pr - TPM - http://www.diamondstarmotorsport.com/brakeparts.shtml
$169/pr/fr, 144/pr/re - Brembo - http://www.machv.com/brbrro.html
$239/pr/fr/re - Powerstop - http://www.machv.com/hapebrpa.html
$130/pr/fr/re - Brembo - http://www.thespeedfactor.com/brake_dsm1.html
$113-170/pr/fr/re - PowerSlot - http://www.xrcbrakes.com/order4.cfm/year/1991/make/MITSUBISHI/model/GALANT
Pads: (all are in pairs)
$55/fr, 45/re - Metal Master - http://www.roadraceengineering.com/eclbrakes.htm
$99-$150/fr, $62-$98/re - Porterfeld - http://www.roadraceengineering.com/eclbrakes.htm
$64 - EBC "Green" - http://www.dsmparts.com/customer/home.php?cat=14
$79 - EBC "Green" - http://www.diamondstarmotorsport.com/brakeparts.shtml
$84 - EBC "Green" - http://www.machv.com/ebcgreenstuf.html
$89 - EBC "Red" - http://www.diamondstarmotorsport.com/brakeparts.shtml
$99 - EBC "Red" - http://www.diamondstarmotorsport.com/brakeparts.shtml
$80 - Hawk - http://www.dsmparts.com/customer/home.php?cat=14
$75 - Hawk - http://www.machv.com/hapebrpa.html
$68/fr, 59/re - Mitsubishi OEM - http://www.machv.com/misoembrakpa.html
$59/fr, 62/re - Axxis Metal Master - http://www.machv.com/metmatbrakpa.html
$99/fr, 99/re - Carbotech Bobcat - http://www.machv.com/cabobrpa.html
$139/fr, 112/re - Carbotech Panther Plus - http://www.machv.com/capabrpa.html
$152/fr, 123/re - Carbotech XP8 - http://www.machv.com/capabrpa.html
$81/fr - Hawk - http://www.xrcbrakes.com/order4.cfm/year/1991/make/MITSUBISHI/model/GALANT
Speed Bleeders:
$24 - http://www.machv.com/speedbleeders.html
-Discount Code for odering from ROCKAUTO.com (thanks to holeshotmoe)
http://www.rochesterdsm.org/viewtopic.php?t=1627
(ea - each, pr - pair, fr - front, re - rear)
